I used the second filament for the first time, and it didn't look thicker (it was a piece cut off from a roll that was already in use before). In contrary, sometimes it was thinner (kind of grazed).
The filament actually gets caught in the Bowden, but far beyond the hotend, sometimes 5 or even 10 cm before.
I didn't see any old filamend remainder (it was red, and easily visible).
As for the hotend version, I suppose it is the v2 (where can I check this?)
I ordered and assembled the Ultimaker in November/December last year.
Printing with the red filament went flawless - as for the feed, don't ask me about other beginner's troubles ;-)
Update: I inserted again the red filament, and it went in much more smoother than the second one (it's "glow in the dark", but I can't tell from which supplier). Such, the problem seems to be the filament itself.
Is this just "bad luck" as for the choice of the filament, or can you fix this in a way?
IRobertI 513
If you have used the filament in the printer before did you snip off the last couple of centimeters off the end? If you didn't the filament can be a bit thicker there and gets caught in the transition between the bowden and the hotend.
It could also be that some of the old filament got left behind as you pulled it out and is blocking the way for the new filament. Look through the side of the tube and see if you can see any junk sitting in there.
Or if you're really unlucky you've developed the dreaded plug. Which hotend do you have, v1 or v2?
