True @gr5 but if it's the transistor of the mainboard fan pwm there's always a chance that just works but 'weird'.
Check the fan control con the Ulticontroller/Control/Temperature/Fan and set it to 255 like gr5 said. Does it spin fully?
If not,
Change fan speed to 1. Does it spin faster at 10 than at 255? (255=100%)
So please check how fast it works at 255 and at 1. If it moves faster at 255 than at 10 then there's nothing wrong with it, also make a video of what's happening, that always helps.
gr5 1,843
Is the fan set to 255 on the ulticontroller? (you can play with fan speeds while printing). not 100. 255. That's all I can think of. Otherwise maybe defective fan? I guess the PCB could be partly broken but usually it fails all off or full on.
