Sorry Stefan - you are right. The title was not clear and has been amended. Thanks for the observation!
- 4 months later...
yep the title was misleading but I wrote down heating cooling and it got me here XD
I solved the problem by updating the firmware of the ultimaker 2, that fixed the issue, but then I stumpled upon a different issue which was the retraction of the filament, was too small so it didn't print well at the start, set the value of the retraction value to make it to 20, that will start printing normally with filament sticking out of the nozzle
Dim3nsioneer 557
Uhm - which of the two plugins you mentioned in the title are you actually referring to?
