Gnevko 5 Posted September 3, 2016 in Cura 2.3 some unnecessary movements (edited) Hi, I'm trying to print an Ultimaker extruder gear (https://www.youmagine.com/designs/ultimaker-extruder-gear-upgrade-w-bigger-hex-nut-hole) with Cura 2.3 and I don't really understand why Cura makes so strange movements: It has no sense at all: more time and more damaged parts: Compare with Simplify3D: Maybe I have some wrong settings in Cura or it's just a bug? Thank you in advance! Edited September 3, 2016 by Guest Share this post Link to post Share on other sites
darkdvd 744 Posted September 3, 2016 in Cura 2.3 some unnecessary movements Use 99% for infill and not 100% Share this post Link to post Share on other sites
Gnevko 5 Posted September 3, 2016 in Cura 2.3 some unnecessary movements (edited) Thank you for the answer! I used 20% infill ... But if you say 99%, ok let's try: hm ... but what is interesting, if I use 3 Wall Line Count it works correctly, because in this case no infill is needed at all ... Edited September 3, 2016 by Guest Share this post Link to post Share on other sites
DaHai8 67 Posted September 3, 2016 in Cura 2.3 some unnecessary movements Looks like you'd found a solution. But it also looks like a bug. I tried various things in Cura 2.3 and could not get ride of that unnecessary traveling issue. However, Cura 15,x seems to handle it just fine. Share this post Link to post Share on other sites
Gnevko 5 Posted September 3, 2016 in Cura 2.3 some unnecessary movements It's not really a solution - just a work around. Do you know how kann I post the bug for Cura? Share this post Link to post Share on other sites
DaHai8 67 Posted September 3, 2016 in Cura 2.3 some unnecessary movements The developers will pick it up here, but you can also post it on their Github Issues site: https://github.com/Ultimaker/Cura/issues Share this post Link to post Share on other sites
