Wall mounts is how we do it at Stockholm Makerspace:
2
The only problem with that file...you can't print it on an Ultimaker Original Even on the slightly larger Ultimaker 2 it has to be done diagonal to fit.
@LePaul, you have definitely not tried enough... :-)
It is actually possible to print 3 at a time on a UM2 printer without doing it diagonally, you'll just have to use skirt with 0 lines :-) I printed six holders for Stockholm Makerspace during a night by using two UM2 printers :-)
It is also very printable on a UMO+ on the diagonal unless you use 8mm brim or more (7mm does actually work)
Really interesting...I wonder if my 4 skirt lines bumped it out?
Then you have a pretty large skirt distance set, with default Cura 2.3 settings i can use up to 11 skirt lines on the UMO+ and it still fits, i have to set the skirt distance to more than 6mm to make it not fit with 4 skirt lines.
Edited by GuestYes...set skirt to 1 and now it fits.
(I always do 4 so I can fine tune the platform if needed)
Default settings in 2.3 for skirt distance (actually I never touch it)
meduza 191
Print a holder to put your power supply on the wall (or on a desk, or whatever): https://www.youmagine.com/designs/a-better-um2-power-supply-holder
LePaul 358
Yeah I noticed the cord from the printer to the brick is shorter than what I was used to on the UMO. I just unpacked my Ultimaker 2 from Fabrc8 last night (refurb) and noticed that the cord length from brick to printer is also short too.
Like you, I was used to having everything on the floor. With the new bricks, I have to have them on the workbench.
Meduza has a good idea...might have to try that. (I also considered industrial velcro to attach to the brick to the back of the workbench)
