Thank you for the answer !
Yes, i did some test prints, but for example I tried to print a box with this dimensions: x=0.16 mm; y= 0.16mm; and z= 0.3. Just to now if this printer is capable to do that and the thing is that I saved in the SD card and later in the um2+ appears the message: there is no info in this file...
Hi @Alexrp92, thank you for your post and welcome to the forums!
The motors are capable of, I believe, 12micron, and the standard nozzle is 0.4mm nozzle.
So you would have to change your nozzle to a smaller nozzle if you want to print something at 100 micron in X and Y.
Why can't you achieve this goal so far? Have you made some test prints that did not come out well?
SandervG 1,499
