Cura 2.1.3 OK but Cura 2.3 -> ringing :(
Spilz
Posted (edited) · Cura 2.1.3 OK but Cura 2.3 -> ringing :(
Hello everyone,
There is something I don't find a way to solve :
On cura 2.1.3, everything's ok, almost perfect
But on 2.3 with the same parameter (i tried) i get bad surface with like "ringing".
I tried différent config and I get always this.
I watched when it prints and it looks like the print has 3 "parts" instead 2 (2.1.3):
- infill
- wall
- some zigzags between wall and infill
i guess ringing is because these zigzags but I don't know where they are from...
on the left : Cura 2.1.3 / on the right : Cura 2.3
on Cura 2.1.3, we have walls parts (green and red) and infill (orange)
5a332189e6368_Capturedcran2016-09-2100_25_49.thumb.png.19a0d89342b2f7549320644c6cc48267.png
but the same slicing with Cura 2.3, there are some yellow parts between orange and green. I guess ringing comes from this difference.(as 2.1.3 and 2.3 are not compatible, I use them on different PC, so I can't have a screenshot now)
Does anyone observes these zigzags ?
Does anyone have the same issue ?
Does anyone know which parameters influence these zigzags ?
Sorry for my bad English and let me know if you don't understand or need more information
Regards
    • 1 month later...
    Posted · Cura 2.1.3 OK but Cura 2.3 -> ringing :(
    It could be coming from infill being printed before perimeters. Try unchecking "Infill Before Walls" under "Infill" and see if that makes a difference. You probably need to add that setting and you can do that by hovering over the "Infill" header and clicking the little icon that pops up to the right.
