Posted (edited) · slowmo since extruder upgrade
hi
UM original (without plus) extruder upgrade to bondtech QR failed. After upgrading we added the settings into the start-gcode section in cura, everything started working in slowmo. Means that the head moves around 1mm/min.
Unfortunately the same with Z and E :-(
Of course we went back to the original extruder but, well, the slowmo problem still appears.
What we tried yet:
- flashed the fw about 5 times with the original one coming from cura 1.5
- removed ulticontroller and tried printing over usb
Sadly nothing helped out. Any ideas if we f.... up the controller ?
thx
    Posted · slowmo since extruder upgrade
    Somebody else needs to pitch in as I really don't know about the UMO, but on the UM2 the e-steps stay the same if you flash to a new firmware, except when you do a factory reset. So my guess is you messed up the e-steps settings, but you should be easily be able to change them back (again by g-code). On the UM2 is easy, you just do it by using tinkergnomes firmeware.
    Anybody able to tell the correct UMO esteps?
    He can do a restore factory settings, I don't remember the name of the option...
    Anyway always back to source, on github marlin for the original says:
    #define DEFAULT_AXIS_STEPS_PER_UNIT {78.7402,78.7402,200.0*8/3,760*1.1} // default steps per unit for Ultimaker
    So 78.7402 for x/y 200.0 * 8?? For z (weird number...) and 760*1.1 for esteps
