hi, thanks for the info...
i had try but cura give me an error saying "file_name is not a zip file" -.-'
any idea?
any idea?
i try also with cure 2.1 and it work but just import the basic printing profile not the printer profile....
Printer profiles can't be imported. You need to change those by hand. They are too fundamentally different to have a conversion script.
The zip file error has been fixed for the release (2.3 is still a beta)
Is there and ETA on the next release??
ok so exist a tutorial or some documentation to learn how to do that?
Is there an ETA on the next release??
We've been in "string freeze" for a little while now. That is the phase of development where all the strings in the application have been sent to a translation agency, so we cannot change or add strings (which means we cannot add or change features, etc). The last couple of blocking bugs are being fixed. That means we're close, very close to a 2.3 release. We can't say much more than that.
For 2.1.x, look here: https://github.com/Ultimaker/Cura/#making-profiles-for-other-printers
For 2.3, select the Custom FDM Printer when adding a printer. It will give you a window where you can enter the most important values for your printer.
nallath 1,067
There is a legacy profile importer. It should get you quite far, but there is no complete 1-1 mapping that works in all cases.
In the profile preferences menu you can import legacy (*.ini) profiles.
