Yes, apparently it is clogged. I do have olsson block. I guess it is possible to print using 0.4 nozzle with wood filament until a certain amount, then it'll start clogging, but recommended to use 0.6?
Thanks gr5!
Thanks gr5!
Yes I have been trying to print with this stuff as well. The bamboo fill. Its a total nightmare, worst clogging I have ever experienced, black stuff spewing out everywhere.
Ill have to get myself an Olsson block and try a bigger nozzle.
Indeed it's possible to print woodfill with a 0.4mm nozzle but it increases a lot the chance of clogging the nozzle.
I print a lot of woodfill with a 0.6mm nozzle and have no issues at all!
gr5 2,230
Almost surely it's clogged. The pieces of wood can get stuck in the nozzle tip. I recommend you print with .6mm nozzle or larger for this reason. Do you have an olsson block such that you can change nozzles? If not I sell them here:
http://thegr5store.com
If you do have the Olsson block you can just unscrew the existing nozzle (while hot - at 150C or warmer) and check it and maybe burn it out in a gas flame until everything in the nozzle is burnt to ash.
