If you want the ease of printing pla and temperature resistance you can try materials like biofilla pla-tec.
That was exactly the case, you were right. I bought an automatic vacuum (Ministar) and with 15 secs of heating time and 2psi seems to work fine. thanks for your reply it really helped.
Thanks I'll see if I can find the PLA spool you recommend. Thank you for taking the time to answer.
Thanks for taking the time to reply, i'll find if I can get it delivered to my country.
geert_2 462
Do you make them on a vacuum thermoforming machine where the model and the plate to thermoform are both placed under a heater, and the hot molten plate is then pulled over the dental model, and sucked vacuum? (Such as the Erkodent thermoforming machines?)
In that case, probably the heat is the main problem. PLA starts getting soft from around 50°C, and your thermoforming plate is heaten to maybe 120 or 150°C or so.
So I would suggest that you try printing the teethmodel with 100% infill, just for testing, and that you put that model in the freezer prior to thermoforming.
Do not yet insert the model in the machine while this is heating up, but only insert it at the very last moment when the heating is finished, and when the molten plate is ready to be pulled over the teeth model. So that the model is still ice-cold when the hot plate is pulled over it. (But only if your machine allows this manual handling, of course; since this may not be possible on fully automatic machines.)
Then try to cool the whole thing as fast as possible, with a cold fan blowing over it, or so. Try if that works, or do you still get deformation?
Otherwise, try printing in a material that can withstand much higher temperatures.
