Doesn't seem to get me there.
I can see that the object fits on the build plate...
I'm wondering if it thinks it's too tall, based on what I believe to be a build area boundary box... How can I fix this?
Most likely it is the default build plate adhesion setting of "Brim" that is making your model too big. Go to advanced mode and check under "Build plate adhesion", change that setting to "Skirt" and reduce the "Skirt line count" to 0 to maximize space on the bed. If not all of those settings are available, hover over the header for that setting group and a small cog will appear to the right on the header. Click that cog and "Setting visibility" manager will pop up with those settings scrolled into view. Enable the ones you want and hit ok.
When you change the adhesion setting you will see that the faint gray border around the buildplate will change size.
As far as I know there is no way to change the direction. But you could try rotating the part to "trick" cura into putting the lines down the other way.
IRobertI 497
