Question about securing your 3D printer
Posted · Question about securing your 3D printer
We recently purchased a Ultimaker for our school and are concerned about theft. Most of our computer equipment is secured via cables to a table or other sturdy furniture. Does anyone have any suggestions for what to do here? We have considered purchasing a cart like the one seen here:
http://shop3duniverse.com/collections/accessories/products/copernicus-3d-printer-cart
Still, it would need to be secured to the cart somehow. Any suggestions would be greatly appreciated.
    Ultimaker original is easy to secure. Just put a metal cable from the front opening to the side opening.
    As for the UM2, you can use the hole in the front right corner to do the same.
    • 1 month later...
    Good ideas from @nallath.
    And if you haven't already (I mean, this thread was created two months ago), get it in a windowless room off the first floor with a door that has a lock on it. Then go as @nallath said.
    That being said, there are plenty of (good) printers lying around in my school, and they just sit in normal rooms. And no one has stolen anything. Yet.
    What we have recommended previously when customers ask is to get a Kensington "security slot adapter" plate, which is normally used to add locking slots to ultrabooks and tablets.
    Just glue the plate to the Ultimaker and use a standard Kensington wire lock to attach it.
    https://www.kensington.com/en/tr/4483/k64995ww/security-slot-adapter-kit-for-ultrabook
        • 27 replies
