Cutting STL Files in Half
ManAtArms
Posted · Cutting STL Files in Half
Another way is to drop it through platform in Cura. It will only print the part that is above the platform.
Then remember that value, flip the part and drop it the total height - the remembered value.
And if you are on win10 the 3d builder app has a similar option and works quite well.
    • 5 years later...
