kmanstudios 1,099
I'll have to take a look. But, for general knowledge, if I place a box in that space, it will need a brim too?
brim is to prevent the curling up of the edges, and this depends on your model, material and settings. Sharp corners with thick walls and solid inside tend to curl up because of cooling/shrinking of the material. If your model allows it you can make circular holes near the corners, or make the corners round (fillet/chamfer) also helps.
There are a few more settings than brim/skirt influencing the total available build size.
Read more details here;
https://ultimaker.com/en/community/23300-cura-23-not-using-full-print-area
Ok, as far as I know, I got it licked. Turns out it was the priming tower was located 'inside the print area'. Once I found that I got my stage together in MAX so that I can output at 100%.
Thanks for the links to the information. It really helped a lot. Can't wait for December to get the printer and test some of this stuff out beyond the software. This is one of the things I could not get to load and slice until recently. Thanks!!
peggyb 169
By default, under the tab' build plate adhesion' (advanced) there is a raft/brim/skirt active, depending on the chosen material.
Playing with these makes the difference, brim line count can be reduced. In the 'view mode'->'layers' you can see what happens on the first layer when you change stuff.
