Hi Ahoeben!, yes in deed i found that "import" tab, but all codes (Even those generated by Cura 2.30 Itself) are greyed out and i cannot select them...
maybe i need to reinstall cura?
Ah, I see. You have to select gcode from the type of files in the import dialog.
@nallath, a "All supported types" would be interesting for all open/import dialogs, if possible.
I have a "All files (*)" option there, it's just not selected by default.
"All supported (*.curaprofile, *.gcode)" would be nice to have as the default option, which is different from "All files (*.*). The File->Open File... dialog already has this.
guys, i found it, I'm using a mac, so i needed to click first in OPTIONS and then comes a dialog where i can choose what kind of file i want to open...
ahoeben 1,965
On the Profiles pane of the preferences (quickly accessible through the "Manage profiles..." option in the profiles dropdown), press "Import" and select your gcode file.
