Hey dude! how's going! Nice to hear you again.
Yes. the shooting is complete and I'm now working on the post-production and editing.
This year I had other tasks to do, i stopped to work on it for several months and so the timing has become drammatically extended :(!.. but yes... I'm very happy about the result! As soon as I can, I'll upload some photoes on my Ultimaker's Profile!
Anyway... about my question on "bearing or sintered bushing": I'm trying to understand why all the ultimakers use the bushing on the external x,y axes, and also the differences between them and their application field.
I guess because the linear bearing (as the name suggests) can only slide and not rotate?
So generally a bearing gives less friction(but only in one direction), what about accuracy? Have them the same "play"? If yes how to mesure?
I saw the ULTI2 has a different bushing. Ithink an "graphite copper bushing".
Which are the benefits? Less friction? Do they need oil or they are "self- dry-lubricating"? do they fit on an ULTI original?
I have alot of other questions, but I risk to go out of theme...maybe later!
Thanks!
SandervG 1,522
Hi SpecialKrio,
Thank you for your post. How are your projects going? Is the video finished already?
Are you talking in general? A bushing is more like a sleeve, in this case a bronze cylindrical sleeve that ensures a smooth transition over the rods.
A bearing has ball bearings etc so there is even less friction.
Or do you mean why we use bearing or bushings in some locations? Or why bronze? I would have to double check.
