Hi @cstcyr, thank you for your message.
Do you have any idea on what kind of thing you want to change on your Ultimaker?
Are you looking for different fans, different bed (less levelling maybe?), make it more quiet, or even change it to 1.75mm filaments (this is a tricky mod).
Check this page for some more inspiration, that has been build in collaboration with our community.
LePaul 298
Hi Christian,
If you haven't touched the UMO in a few years, I would start out with some sewing machine oil and lightly lubricate the rods. I left my printer idle for a few months and when I went to use it again, it was a noisy awakening! A little goes a long way. After doing that, move the print head around and it should move freely.
There's a lot of sources for hacks and tweaks. Thingiverse and Youmagine is full of them but seldom is there much discussion about what's worked and hasn't. If you are looking for some specific UMO tweaks and some conversation about them, read here.
I don't know a lot about the eBay type heated beds, I went with the official one through Ultimaker last year. It took a bit of a learning curve to use it right and it really makes a huge difference. You can use a lot more materials and kiss blue tape goodbye.
