NFC specifications
si2w
Posted · NFC specifications
Do someone have the specifications for the NFC tags and readers ?
What kind of NFC tags are used ? Do someone have a datasheet or the part number used ?
I would like to be able to read the data on the tags and write new tags from a raspberry pi/arduino
Thanks
Cheers
