Calibrating the Extruder Advise Needed
Posted · Calibrating the Extruder Advise Needed
Found a video on You Tube
Dealing with calibrating the extruder and wanted some advise,, they are using a command line in Octo Print is there a better way to do this ie.software Could? Cura Do this, or should I use Octo Print.. I'm wanting to check to see what exactly is happening.
