tinkergnome 929
Would the correct process be to do, MATERIAL - UNLOAD, then change cores, then MATERIAL - LOAD ?
basically - yes.
"Material/Print core" -> "PrintCore 2" -> "Change"
is intended to guide you through these steps, i think?
Edit: alternatively... RTFM!
1
neotko 1,418
Well, the material doesn't fully unload from the tube to avoid small parts of filament (blob on the tip of the unloaded filament) to fall inside the feeder so indeed after the filament is move out by the core change you need to manually take the filament (keeping the feeder lever up) and then removing the filament spool. Then when you place a new pla spool you can use the Load material
Edited by GuestLink to post
