Ultimaker3 firmware : let's make things beter ...
Posted (edited) · Ultimaker3 firmware : let's make things beter ...
I know the UM3 software is still 'in the making' so let's collect some user experience to improve the firmware.
ANYBODY, please share your experience on unexpected behavior of the firmware.
@SandervG I'm sure you'll be able to get the developers notice this thread.
Here's a few of my findings on changing cores and materials;
scenario1;
Changing a CORE;
- change core2
- heatup, unload material (just a bit)
- take out BB core
- Put in AA core
* WARNING: "core not compatible"
- click continue
- "place a printcore"  (he hello... printer, there's already one in)
Now there's no way to get out of this menu, you can try to remove and place again, wont help.. only option is REBOOT.
Suggestion: let me simply overrule the warning, and preferably directly manual select a different material.
scenario2;
When I first unload a material, and then directly after that 'change printcore' the printer will warm the core again to remove the material that's not there .... waist of time, but ok I'll wait...
I place a new core, the printers tells me to remove it (????) I do that, and directly get a 'max temperature error'
Can not get out of this, need to reboot...
and about updating firmware;
If you go to update firmware, the printer will update even if the installed firmware is still the latest. I would like to see if there's a new version available and only then decide to update Y/N
Posted · Ultimaker3 firmware : let's make things beter ...
I gave it a little more thought, and I think I would like the material/core change part of the firmware to look like this;
Unload material;
(just unload, scenario; you want to take out nylon, or PVa to store it, but don't want to do another print now)
load material;
just load material, the correct core is already loaded.
change material;
only change material, you want to keep working with the already loaded core.
change core;
this is a bit more complicated. I see 2 options, the 2th is probably the best;
simple;
Always fully unload/change the material, assuming in 99% of the time you want to change material when you change a core (not true if you change from 0.4 to 0.6 f.e) -plus; no risk of reentering material with a string on it, you can cut it to a nice tip again.
After change core, ask question, do you want to load material Y/N.
less simple;
Start with a question, "do you want to fully unload material Y/N" and based on that do a "short retract" or fully unload of material.
Anyhow the "change core" part of the menu needs the option to at the same time change material.
