For anyone wondering, I don't know if it's a local problem, but I'm pretty sure it's not,
but in Microsoft Edge instead of showing the stream, it starts downlading it as a video. Streaming works in Google Chrome
This method doesn't seem to work (anymore?). UM3, firmware 3.6.2.20170322. Unless I'm doing it wrong....
http://[ip address]/?action=stream
just redirects to
http://[ip address]/start.html
and prompts for the Welcome to Ultimaker 3.
Camera streams OK to Cura though.
You are omitting the port number (see the :8080 part):
http://[ip address]:8080/?action=stream
Thanks. That works.
neotko 1,418
Hi and welcome. You can access your um3 camera using your printer IP address at "xxx.xxx.x.x/?action=stream"
Edit:
http://xxx.xxx.xxx.xxx:8080/?action=stream [gr5 edit: don't actually click on this link! You have to put your printers ip address here! Danger - sexual content at the xxx address.]
ahoeben 2,047
Minor correction in the address: http://xxx.xxx.xxx.xxx:8080/?action=stream
(see the :8080 for the port to use, and the %22 at the end is unnecessary)
neotko 1,418
True and forum copypaste error. Ty
