Hi @Melka,
Thank you for your message. Sorry to hear your print stopped halfway.
Was this the first time it happened, or did other prints stop halfway too?
Like @Neotko says, a log would be very helpful to understand what happened. Perhaps something went wrong during slicing and the g-code was corrupted, or perhaps a glitch in the power supply.
Lets see if the log can tell us more.
The nozzle looks like you could clean rather easily with a paper towel when it is hot. Don't burn your fingers, but warm it up enough so it gets soft and you can just wipe this filament off.
There are also quite some positive reviews about the Ultimaker 3 already, so I like to think of it more as an incident. If it has happened before, and you can not trust it with long prints, we should definitely look into how to fix that for you because like you said; the Ultimaker 3 is a reliable and trustworthy machine. So should be yours.
Looking forward hearing from you!
neotko 1,415
Dunno men, first thing I would do if it where my machine would be to dumb the logs to the usb and upload them on a dropbox so we can take a look, it might give a clue of what happened. The dumb logs is on Maintenance menu, not sure if you need to be on DevMode to access that option.
