Thanks for your answer !
If you don't mind we will use this thread to communicate when an fixed version is ready.
No problem. I wait forward to a fix. This plugin seams great !
There is an updated version ready to be tested:
https://github.com/Dim3nsioneer/Cura-Plugins/raw/development/TweakAtZ_V5.1.1-RC1.py
Thanks for info.
Unfortunately it seams that this version did not change my problem.
The version delivered in 2.3.1 as an issue for layer changes under the first mm.
It have submitted a PR to fix this some time ago (see here), if you copy that file in your install tree that particular issue will be fixed.
(The problem is not really at TweakAtZ issue, it is CuraEngine droping the leading 0 for dimensions smaller than 1mm...)
Edited by Guestnevermind
Edited by GuestI am using TAZ for all my prints, and for me it just works...
... but it is with my UMOs, so no UltiGCode -- that might be the difference.
Dim3nsioneer 551
There is a bug in the current TweakAtZ. It will soon be fixed (either by me or by Ultimaker). If you don't mind we will use this thread to communicate when an fixed version is ready.
