Examine the tiny pyramids in the gnurled sleeve in the feeder. They can go from pointy to rounded after years of printing. Or after only hours of printing CF filament.
You want the feeder tight. Tight enough that you can see a pattern in the filament. One of these is a little too tight and the other too loose. You want the tension more like the one on the right but not necessarily quite that tight.
Are you certain the bowden is all the way in? It can get caught up on the edge of the teflon part. If you have that stupid aluminum spacer I recommend you get rid of it and print one instead or drill a hole in it so you can see what's inside.
https://www.youmagine.com/designs/um2-spring-replacement
Also experiment a little - cut off the end of the filament so you don't keep grinding the same exact spot in the feeder. Then insert it and when it gets to the end stop it right away and use "move material". Move the material down until it stops. If it's not coming out of the nozzle move it up and push the bowden every which way as you move it back down to get over the various sharp rims it can hang up on.
fbrc8-erin 235
Have you replaced the Teflon coupler? How many hours of print time do you have on the machine?
When you replaced the bowden tube: can you confirm that the widened out end is in your feeder and the flat end is the printhead?
Is your knurled sleeve still tight on the motor shaft?
