mastory 31 Report post Posted December 11, 2016 in Cura 2.3.1 closes after title screen. Won't run (win764b) (edited) Previously I had the 2.3.0 beta running. I uninstalled that version, deleted the remaining pluging folder as well as the Cura2.3 folder. The last image on the title screen says "loading scenes" or something similar. Then the process closes. I am running win7 64b. Anyone else have a similar issue? Edited December 11, 2016 by Guest Share this post Link to post Share on other sites
mastory 31 Report post Posted December 11, 2016 in Cura 2.3.1 closes after title screen. Won't run (win764b) I looked up the system requirements for Cure which specifies OpenGL 2. My graphics cards supports OpenGL 4.1 which I would assume would be later and inclusive of 2.0. I'm thinking this wouldn't be GPU related since I have been running earlier versions of Cura 2 including the latest beta Share this post Link to post Share on other sites
Torgeir 79 Report post Posted December 11, 2016 in Cura 2.3.1 closes after title screen. Won't run (win764b) Hi mastory, Also have Win7 64 bit (pro). Got the very same problem as you listed here, so just to mention did you got to this directory: C:\users\"your_Name"\AppData\Local\Cura\ ? In here you'll find the setup for your previous "Cura version", just delete "cura.cfg" then try to restart Cura. I'd deleted this whole catalog and reinstalled, then I could start Cura 2.3.1 However, could not use any of the newer Ultimakers from UM2 and up.. But could if I installed a custom version of (in my case) an UM2. Hope this will help. Good luck. Thanks. Torgeir. 1 Share this post Link to post Share on other sites
mastory 31 Report post Posted December 11, 2016 in Cura 2.3.1 closes after title screen. Won't run (win764b) Thanks Torgeir. This made it work for me. Share this post Link to post Share on other sites
