Thanks Neotko... You mean the second one? The one not making noise?
Gracias Neotko.. Cuando dices "La segunda" ¿Te refieres a la impresora que aparece al final? ¿La que no hace ruido?
Edited by GuestThanks Neotko... You mean the second one? The one not making noise?
Edited by GuestOn Both can happen. The one with the tension on top (relaxed) if the feeder diamonyshaped tooths grind the filament it might start slipping the filament. The one with the tension on the middle because uses more force it might grind it faster since has more pressure but also it might keep the grip more time since it can hold more pressure on the filament. I really liked the spot in between. But also I wasn't able to do that many retractions with it as I can do with my mod that uses bondtech. Isn't very expensive if you print all the parts and reuse the motor.
But it requires a good knowhow and a decent modding skills. (Is not plug/play at all)
https://ultimaker.com/en/community/34976-neotko-fatiroberti-bondtech-adapter-feeder-for-um2-um3
neotko 1,418
The feeder won't brae that's almost for sure. But the filament might grind. For my prints that require 1-2k retractions in 25mins print I use other feeder.
