Hi there,
I am more than a year on and my belts are still tight.
For maintenance, I find it useful to clean out the nozzle from time to time. I atomic pulls using nylon, ideally, but PLA does a decent job too. I also occasionally put that eSun cleaning filament through, just for good measure. It catches stuff that even the nylon misses. This kind of stuff is good to do when changing from dark colours to light colours and/or when switching materials. But I do not always do that. If I see dark specks show up in my light prints, this is the solution to that.
Cleaning the bed with alcohol periodically is good for a fresh reset of the build plate. Some people just leave the glue on, for example, and keep adding more. I have found that too much glue can also cause bad adhesion, so periodic cleaning is good.
And lastly, it is good to check on the TFM coupler (UM2+, no spring) once and a while. Doubly so if you still have the PTFE coupler (UM2, with spring). If it looks warped or very burned inside, then it might be due for replacement. It is considered a consumable part, though the TFM ones last considerably longer.
For the most part, that is it for maintenance. Most of these things I only do with I think they need it or when settings that used to work, are not so perfect anymore.
I suppose this is just stuff I picked up from reading the forums, reading about the issues/problems others have and see what answers come. I agree that it should be all written down in a proper document though.
Anyway, hope this helps. Happy New Year!
- 1
cloakfiend 995
I'm the same as you a year on, not sure either, but I'm pretty sure we're gonna have to tighten the pulley screws at some point. the belts need to stay tight.
