I didn't see in Cura 2.3.1 where you can make any Start gcode as you could the old Cura
In my case, for my UMO, I like to extrude 15 mm of filament before the print begins.
What I do now is open the saved gcode with Notepad (assuming you use Windows) and manually edit the line, then save it. It's an extra step that's a little annoying, but works
Umo and um3 are parallel words. The purge command is a single gcode that readies the core. On umo is just a gcode sequence. Also you can edit your umo gcode start on the machine Preferences.
And ofc you could change the gcode manually to ourge more material, but that would confuse the machine prime sequence a bit. On S3D I make my own start sequences for um3. Not easy, but doable. Ofc Cura doesn't allow the users to have full control of the gcode...to make things easier...?
neotko 1,417
UM3 uses a G280 gcode command that makes the initial purge.
To edit the amount of filament purge at the start of a print you should edit the printer_preferences.json that's on /usr/share/griffin/griffin/machines/ it controls everything and you need to access by ssh to your printer using root as user and ultimaker as password, to edit it. Also, if you edit it wrong the printer might need a reflash, and if you edit something that you shouldn't it might even make the machine not starting properly. Anyway after this warning, I edit it using 'vi' (google vi linux to know how to use it) and I change often the parameters to test things.
Easy? No. Can the start gcode modified on cura? not at the moment.
LePaul 330
