Did you do a factory reset? It's an option in the menu system somewhere. It resets the eeprom settings that s3d may have modified.
S3D by default only changes the feeder motor
amps, but it doesn't write that info, so after a reboot all gets back to normal.
Try to run the calibration process to see if all is ok.
gr5 2,002
