I tried pasting the resources for a Type A Machines printer into Cura 2.5, and it is not recognized.
If you tried the same files as the ones you linked to in your PR on the github project, your definition file referenced a file to inherit which did not exist.
ahoeben 2,047
By "Create a machine profile", they mean a .def.json file like the ones in your Cura/resources/definitions folder. You cannot create those from inside Cura, you have to use a text-editor.
Official machine definitions can define many, *many* (many!) more parameters than what you can set with the Machine Settings screen. The "Custom FDM Printer" route is meant for end-users of printers for which there is no official machine definition.
doulos0523 0
OK
I will try it.
Thank you very much.
