kenjkelly 0 Posted January 15, 2017 in When will the UM3 Door be available? Hi Folks. Ultimaker states for the older printer: "The use of the door is strongly advised for most filaments that print at higher temperatures and which are likely to have problems with layer bonding. Because the door controls the temperature inside the printer, it prevents delamination and improves the surface quality of the prints." When will Ultimaker provide a door for the Ultimaker 3? Share this post Link to post Share on other sites
ultiarjan 1,076 Posted January 15, 2017 in When will the UM3 Door be available? No idea if Ultimaker will ever sell one, but most UM2 solutions work just as well, like this simple one; https://www.youmagine.com/designs/um2-minimalist-front-panel There's one main difference, when you want to use the max bed size of the UM3 the head sticks out a tiny bit, so you would need a door that has room for this. With the current default setup and priming positions you will not have an issue here, but I hope someday UM will let us set the priming position in CURA to use the full depth of the bed. And if you need a top cover, for ABS printing, this will also fit the UM3; https://www.youmagine.com/designs/ultimaker2-top-cover-clips 1 Share this post Link to post Share on other sites
kenjkelly 0 Posted January 17, 2017 in When will the UM3 Door be available? (edited) Thanks @ultiarjan for the very detailed reply. I'll definitely take a look at those. I'm was hoping for more of a turn-key system for Ultimaker 3, but maybe those will work. Edited February 10, 2017 by Guest Share this post Link to post Share on other sites
kenjkelly 0 Posted February 10, 2017 in When will the UM3 Door be available? I decided to wait for real Ultimaker 3 doors, while continuing to look at already-enclosed products. Share this post Link to post Share on other sites
nallath 526 Posted February 10, 2017 in When will the UM3 Door be available? I've had pretty decent results with a big cardboard box. It doesn't look that fancy, but it works like a charm. Share this post Link to post Share on other sites
ffco 3 Posted February 13, 2017 in When will the UM3 Door be available? Printed Solid has some for UM3 and UM3 Extended https://printedsolid.com/products/ultimaker-3-safety-enclosure-kit Share this post Link to post Share on other sites
