Jep, this is also what I think is what happening with ABS.
I bought one role of whit ABS and the first few prints where really beatiful, but after a few days things went bad. The surface of the prints got small -almost unvisible- imperfections and when I tried extruding in the air the string that came out had bends in it and also one small bubble.
I really think that moisture in our filaments is causing us trouble. You can observe that this experience is made alot since there are many entries on groups and forums that start with " I bought a printer and the first few days/week it was really nice but now my prints don't look as well as before. What can I do?"
How about a "dry chamber"? A box with silica-gel where one could store the filament without letting it absorb moisture.
Fabian
1st Edit:
Found this enlightening video on the use of silica-gel in a dry chamber:
2nd Edit:
And a promising, low cost approach that also solves the dust buildup problem:
http://www.thingiverse.com/thing:62826/#comments
matengi 0
Polyamides absorbes a consideral amount of water, depending on the type, because of the hydrogen bonds of the molecules. For PA 6.6, 2.5-3% are usual. Polyamide parts coming out of a injection molding machine are rather brittle. Often a water container is placed below the machine. After some hours of waters the parts are as flexible as PA usually appears.
Heated and dried PA filament will therefore again absorb water from the environment and end up as heavy as before. However the heat treatment may reduce bubbles and vapor coming out of the nozzle during printing, best is to dry the filament just before usage.
