You can change the location of the rendered bed by adjusting the "platform_offset" variable in the .def.json file.
Cheers for that.. I checked the "printrbot_simple.def.json" and there is no "platform_offset" variable.. But I checked another json file and can see the syntax.. So I added it to the Printrbot json and now I can't see Printrbot in the list.
There must be something about the syntax that I don't understand. I changed this:
"metadata": {
"visible": true,
"author": "Calvindog717",
"manufacturer": "PrintrBot",
"category": "Other",
"platform": "printrbot_simple_metal_platform.stl",
"file_formats": "text/x-gcode"
to this:
"metadata": {
"visible": true,
"file_formats": "text/x-gcode",
"platform_offset": [0, 0, 0],
Any ideas?
nallath 1,124
