Thanks for reply.
How do you think the Solex hardcore six pro would go in T°C ?
For me I though it could go to 280°C and not far away. Isn't it ?
If not, how do you think could it goes ?
Thanks for reply.
I'm not sure I understand your question.
Normal Ultimaker Core rated to 350C (not 250C!)
Normal 3dsolex hardcore rated to 350C
EHT 3dsolex hardcore rated to 360C (needed for PEEK)
All of this is well above 280C.
But the printer itself will allow the core to go above 355C without software modifications. So the EHT is for people who can edit the UM3 firmware and experiment.
The hardcore six pro can go as hot as the normal Ultimaker core because (for now) it is using the same heater, the same temp sensor, the same everything - except the aluminum cooling fins, the block, and the nozzle. Aluminum and brass should be fine at 350C as far as I know.
It is possible that Ultimaker is wrong and that it can not go to 350C. I don't know and I haven't tried that hot yet.
Edited by GuestI'm not sure I understand your question.
@gr5: ...but keep in mind that the official maximum operating temperature is 280C
From the UM3 specifications:
Nozzle temperature 180 ˚C to 280 ˚C
gr5 1,873
A clarification - the EHT is not all metal and should work with PLA but it's experimental - it has some unusual materials inside that can withstand the heat just fine but the question is will PLA stick to it and cause problems?
Unless you want to experience the headache of bleeding edge technologies then stick with a core that we know works great for PLA and other materials up to 280C no problem.
