Thanks @Labern
Yes 738 works really well and is what I am using.
369 Steps is what the UM2+ uses and because you are using the original stepper that does double the amount of steps per rotation then 369x2=738
Thanks @Labern
Hi Labern.
I'm modding my UM2+ (upgraded from 2) with the Mark 2 second extruder, Downloading your modded 22mm um2+ housing to fit a 2nd um2+ feeder and um2 old motor.
Should I be using the above 738 e-step value in the firmware? Any thing else...how about to reverse the motor rotation?
Thank you in advance?
Labern 772
