I think @skdesign wants to do the slicing on his OctoPrint instance. OctoPrint has a plugin which uses the 15.04 version of CuraEngine, which uses the 15.04 profile ini files.
Having said that, as the author of the octoprint plugin I agree with @nallath that you have much more control over the placement and print settings if you use Cura 2.3 (or 2.4 beta) with the OctoPrintPlugin.
nallath 1,123
Why are you using cura 15.04 for this? If you want really awesome octoprint support (eg; Directly stream from Cura to octoprint) you should use cura 2.x and download the octoprint plugin (https://github.com/fieldofview/octoprintplugin)
