kmanstudios 1,120
Since you have a new UM3, are you getting the same issues with the included PLA that ships with the printer?
Whilst you temp. is not making a difference for you, you must try and print as cool as possible. Reduce you temp until you get under extrusion then back off 5 degrees.
My retraction settings (for PLA) are
Distance 5.5mm
Speed 50 mm/s
Minimum travel 1.0mm
Maximum count 90
Min. extrusion distance 0.2mm
This is not to say they will be the best for you, you should do some tuning but maybe they give you a start.
Important to realise that filament impacts this; i.e. your settings which work well for one filament may need some tuning for another filament (even sometimes the same filament type e.g. PLA from the same manufacturer) - not usual but can happen). In my limited experience I would say that different filament types, e.g. PLA vs Nylon may well need tuning.
I have also found that colors from the same manufacturer can make a difference too.
Different colors from the same manufacturer most definitely often require different settings. I've found the more clear/glass filaments tend to require more retraction.
dancorrigan 0
Good luck. I came here searching for the same answer. I'm honestly not too impressed with Makergeeks Maker Series PLA. The Black HD Glass filament was a giant pain in the butt and was string city. I am testing a Makergeeks silver at 6.5mm at 45mm/s retraction, and it still hasn't improved much.
