Measure the thermister when it is not connected to the utlimaker board and make sure it measures around it's nominal value (very very roughly around 100K if it's a 100k thermistor - 50K might be normal also). Try to include all the wiring in your measurement - there may be an open (or possibly a short) in your wiring.
Heat up the thermister by touching it with your fingers or other heat/cool methods. You should see the resistance change immediately.
Once that is working, connect up the thermister to the ultimaker, turn on the power to the ultimaker. Now you have a resister divider so that the voltage at SIG should agree with this formula:
Vsig = 5V X Rthermistor / (Rthermistor + 4700)
Daid 303
Should be between SIG and GND, as the 4.7k resistor is between SIG and 5V (on the board)
