Hello
Thank you for the fast answer.
Its ok that this is nowmal but at first the printer was 100% accurate. This is very strange.
Is there a setting in the firmware or cura where i can set a value so the printer can correct that issue? The troblem is whrn you want to use standard parts like screws or bearings and they dont fit?
Best wishes
Hoonse
gr5 1,870
Well this all sounds normal. The bottom layer is probably squished a bit so the bottom 1 to 3 layers are probably indeed .25mm larger on each side or .5mm larger. This is usually good because the part will stick well if you squish it in. However if dimensions must be more accurate on the bottom layer then you can move the heated bed a little farther from the nozzle until it's just right. Just be warned that your part might come off the bed during the print. Especially large parts.
Now the second issue is unrelated. vertical holes always come out a bit small. Usually about 0.5mm for me. Possibly 0.7mm - not certain. This happens with PLA on every printer out there. It is caused by 3 factors: circles are modeled as polygons *inside* the circle - it's a cad thing - material shrinkage - but 90% of the problem is caused because the filament comes out of the nozzle like snot. It sticks to itself and is shrinking in the first few milliseconds such that it's like a liquid rubber band. As you place a layer down in a circle the pulling of the liquid pulls inwards.
I have tried many things to fix this and by far the best is to simply add 0.5mm to all vertical holes in CAD (horizontal holes don't have the same issue). The latest cura I think even has some kind of new correction factor somewhere that addresses this but will also make your overall part a bit bigger I think. So best to do it in cad.
