What happens if you put the head in the front right corner? Does it still go to the back and left?
Might be a dead X or Y motor
Yes it does
Yes it does
I think is missing to touch an endstop, therefore it keeps searching for it. Move manually to the corner the head (while off so steppers are unlock) and fell if clicks x/y endstop. Inspect them visually for bending.
I have tried it. It maked contact with the end stops. I can hear them both clicking. The printhead seems to be stopped by the end stop on the left, but tries to go to the back despite the fact that it touches the endstop
Thanks for the replies
then try this
Put it in the front right corner, make it home and click on the endstop with your finger (or anything to activate it).
Do this on both endstops, it should stop the move of the head in the corresponding direction (X or Y), if it doesn't stop then check the connections on the electronic board, and also check if you didn't pinch the endstop cable behind the feeder motor (that happens a lot).
then try this
I have tried it. One of the end stops seems to be not doing it's job. Its the one on the left. I have checked all the wiring and everything seems to be OK.
As you can see in the video both end stops click. I think the weird part is i printed something without problem, but when wanted to print another think suddenly this problem occured
Anyone?
I would check the faulty endstop with a multimeter.... or just replace it...
Or if your in a hurry cut of the cable close to the end stop and solder on new wirering...
Yes you probably need to replace the endstop, contact your reseller!
DidierKlein 726
