Yes using the Matchless V3 , but did not change the 25W heater.
Should have try the 35W heater.
Currently can print but need 230 deg for PLA vs 220. and also slower print speed.
Tried both the 0.4 and 0.6mm nozzle - 0.6 mm perform better.
Will change the heater later
Labern 774
Do you have the Olsson block or the Matchless V3 like your title shows?
Also why are you using a stainless steel nozzle for PLA? Stainless steel nozzles have bad heat transfer and are not suited for PLA.
They are not even good for abrasive materials. E3D Hardened nozzle and the Ruby nozzle are a lot better.
If you have a UM2 then I would recommend upgrading the heater. The UM2 has a 25w heater and UM2+ has a 35w heater.
If you want to print with the big nozzles like 2mm then I would get the 40w.
Edited by GuestLink to post
