Why you want to merge 3 parts?
The UM3 can print in 2 different colors/materials.
You can try to merge 2 parts in an other 3D program...
You can merge lots of parts and mix the 2 colored materials to make other colors.
designed the 3 parts using OnShape, and downloaded them as separate STL files.
Did you draw them in the same part file or separate? Are the parts designed in the correct position to the origin in Onshape?
1
Siebet 27
