strongest possible prints (PLA)
cairn
Posted · strongest possible prints (PLA)
http://taulman3d.com/alloy-910-spec.html
Link doesn't seem to be working..
I'm interested for a kick ass material for crash tests (base of bindings, top of trucks and hubs
I remember the bad old days of Bennet skateboard truck base plates: they broke so often I gave up on them, and would be wary of using plastic (even injection-molded glass-reinforced nylon like the Bennets) for any truck component. My application is a little less demanding, but I've had to abandon using printed parts for testing.. just not strong enough for safety :(
    I would also think of Taulman Alloy 910 as a very suitable material. Still didn't try it myself, but looking at most reviews and youtube demos, it seems perfect to me for this type of stress.
    • 2 weeks later...
    Posted (edited) · strongest possible prints (PLA)
    Going to weight in since we print functional parts on a weekly basis at work.
    ABS = Durable, impact resistant
    PETG = Flexible, Durable
    Nylon = Strong, Flexible, Durable
    PET = Strong, Flexible, Durable
    PCP = Strong, Flexible, Durable, Heat Resistant
    For your application you will want PETG if you need some flexibility, ABS if you do not. Nylon is a good choice too. Word of advice, PETG does not play well with supports (PITA to remove) unlike ABS.
