How to print with two cores?
Trebor
Posted (edited) · How to print with two cores?
Could anybody tell me, what have I to do to print a model with two colors? Do there exists a workflow witch explains the procedure of printing with two colors?
Should I generate two files as STL, or would it be better to eport two OBJ files to cura?
How can I assign both PLA colors to this model? How can I make color changes, for example if I will change the black one vs the red one?
Thanks a lot for helping.
    • 3 weeks later...
