I contacted fbrc8 for support on this, and even though they are closed on the weekend, Erin (Co-Founder of fbrc8) helped me diagnose this. She was fairly sure this was the wifi card, and she was right!
Erin sent me very detailed instructions on how to remove it, and after I did, the UM3 started right up!
They are processing a return for my wifi card, but I'm happily printing using the wired LAN connection.
So I've learned a couple of things:
1. If your UM3 spins the fans up for a couple of seconds and then the printer acts dead, you probably have a defective wifi card that is drawing too much power. And
2. fbrc8 (and Erin in particular) is awesome!
3
ultiarjan 1,222
first the obvious, is you power plug pluged in deep enough? there's a locking mechanism in it....
Else with this issue on a new machine I think you should get in touch with the re-seller.... maybe it's a bad power supply? Do you (or someone close to you) have an UM2? in that case you can test with that powersupply, it's the same....
