Irregular Layers, Print Quality
Posted (edited) · Irregular Layers, Print Quality
Hello,
I built a Ultimaker 2 Clone Printer (Thingiverse Aluminum Frame Version). Every part is copy of real Ultimaker. Mainboard, screen, print head vs.. As you can see, when i printing 0.2 micron, 0.1 micron or even 0.06 micron, layers are not regular as original ultimaker.  I'm trying to understand what is causing this problem. X.Y axis or Z axis? And the builtplate vibrates hardly when its moving high speed like; end of the print or Starting Print. Is it causing the problem ? I'm waiting your help.
e10ft.jpg Spiderman 0.06 micron (Ultimaker Silver) Print Temp: 210
zleu02.jpg Yellow 0.15 micron (Colorfabb Flurescent Green) Print Temp: 210
Thank you :)
    Posted · Irregular Layers, Print Quality
    IMO:
    Bed PID is the main source on um2 of layer banding, solution is to install tinkergnome firmware:
    https://ultimaker.com/en/community/33482-tinker-firmware-introduction
    Other things:
    - Bad quality linear bearings
    - Bad z nut
    - Hotend heat oscillation (for this you need to check the temperature of the hotend while was printed)
    About pid https://ultimaker.com/en/community/7907-horizontal-banding-on-um2
    More about pid and bad bearings
    https://ultimaker.com/en/community/20188-smooth-walls
    IMO:
    Other things:
    - Bad z nut
    These are useful information. Thank you :)
        • 9 replies
