DidierKlein 729
Hi and welcome!
Printing NinjaFlex on a bowden printer is not easy.
I made a small tutorial on my website about this if you want some hints.
But really it applies more to semiflexible filaments. NinjaFlex is really flexible and has many issues with the bowden printers like Ultimaker. It can be done but needs quite some time. Good luck!
Labern 775
Ninja flex is not a beginner filament.
What settings are you currently using?
You need to print slooooww and at around 240 deg. Not that you require good ventilation when printing at high temp as it releases toxic fumes.
Also wipe a bit of oil on the filament so it's not so grippy in the Bowden tube.
Turn off retractions as well and set the travel speed to 250 - 300mm/s
