yellowshark 153
Hi @ahoeben. I just tried that but it still did not update. I investigated a bit more. I checked the printer file abc_settings.inst.cfg in folder ....cura/machine_instances and saw that the timestamp for the file had been updated. I opened the file and saw that my changed gcode statement had been saved correctly .
I then loaded a model and checked the generated gcode and this was using the old gcode not the new gcode stored in the ....settings.inst.cfg file. Double checking the machine settings in Cura, they were showing the old gcode.
So it seems like the settings are being updated but the file that is saved by Cura is not the file that Cura is using.
ahoeben 1,722
Something to try: after editing the gcode snippet and before pressing "Ok", use the Tab key to change the focus to anothe control. Then press "ok".
Let me know if that fixes it.
